in the elevens
- Sep 27, 2010
I recently had the ignition module and coil replaced.
I started my car <87 T-Type> this evening and the idle was real high,so i shut it down and turned it back on and it was high again and sort of choppy.
So i started looking thru the scanmaster and when i got to tps it was 1.57 sitting at idle....
So i readjusted the tps to 42 and then i noticed that while driving if i took my foot off the gas the tps would go from 42 to 34 to 20 back up to 38 and so on...
I've never paid attention to the tps setting before once i set it usually 42 and anything over 4.60 wot.
My question is,is it normal for a tps to fluctuate at idle while the car is sitting at idle? My guess is no but i just want to confirm it.
Would you replace the tps or look somewhere else first?
Thanks for your time and thoughts in advance
