TPS question for friend on a 5.0
Otto J
we installed a FasT system on a 92 thunderbird with a 5.0 the only problem with the install is that the tps is 90% when closed and tehn goes down as thrlttle is applied.I know swapping the wires will not change anything.Other than trying to find a tps that sweeps the opposite way is there any way to reconfigure the ECU to acccept the current one?
Thanks in advance
Otto-
Swap the 5 volt and ground wires. It will fix the problem.
Unless this TPS is unlike any other I've ever seen, that is.
thanks Craig. That worked out for us.
Appreciate the help.
Otto
