TR6 install question
Danster
Senior Member
I am finally putting my engine together and have a question on the TR6 install. I purchased the Cruz mounting late for the TR6. My question is, does one still use the factory bracket that held up the module/coil to keep it level? That's the way I have it at the moment but wanted to check with others.
Dannyo
Yes I believe you are supposed to use the stock mount .
I used spacers on with my Cruz mounting plate. Use washer or whatever works.
I have the Cruz mount. What are the spacers for? Where were they used?
Remove the stock mount,and the two bolts.you will use the two spacers to get the mount above the fuel rails with the longer bolts. Worked out very nice.
The mount is drilled for ether TR6 (3 holes) coils on top of TR6 or coils on valve cover (4holes) for mounting the coils on bracket and TR6 somewhere else.
I mounted my coils on bracket TR6 on drivers finder, lot more work. But I like a challenge.
