SignUp Now!Timing gears and chain immediately if original!
Add Powermaster to the list, unless you stay on top of it few times a year. its a problematic system. vac conversion all the way.
If you are the 1st owner ,no biggie. the key is the history of the car and maintenance records.These car are very fond of giving
you some type of signal when the $hit is about to hit the fan. I know of many of these cars with 75K to over 100K miles on them
still functioning with OEM parts that you mention above. unless you are attempting to upgrade parts... IF IT AIN'T BROKE DON'T FIX IT..
Then, add RMI. Helps with keeping the nasties in check.Gotcha.. With 19K miles the history of car should not be very lengthy. In thread #6 you mentioned maintenance and repairs that you are attempting, all's good. Everyone has opinions , for VC gasket l prefer Fel-Pro blue rubber.
I'm kinda old fashion on Rad flushing . A flushing solvent and water hose and drain. Don't trust those power flushes.
