Track Times TTA#884
TTA850
Details of the run:
60' - 1.943
330' - n/a
1/8 - n/a
MPH - n/a
1000' - n/a
1/4 - 13.372
MPH - 104.117
Sorry the track sucks which is why I went out on ET STreets - here is another run thats more complete and my best MPH with the car:
60' - 2.144
330' - n/a
1/8 - 8.714
MPH - 82.834
1000' - n/a
1/4 - 13.434
MPH - 106.066
Turbo Trans Am #884
EMPTY WEIGHT:????(cloth/hardtop car)
BLOCK:stock
HEADS:stock
CAM:stock
TRANSMISSION:stock
TORQUE CONVERTER:stock
DIFFERENTIAL:stock with 2.77 gears
INTERCOOLER:stock
THROTTLE BODY:stock
RJC POWER PLATE:no
INJECTORS:Blue Tops
THERMOSTAT:stock
TURBOCHARGER:stock
VALVE SPRINGS:stock
MAF:stock
DOWN PIPE:stock
EXHAUST:stock
FUEL PUMP:stock
FUEL PRESSURE REGULATOR:stock
FUEL PRESSURE:stock(45psi?)
ALCHOHOL INJECTION:no
PROPAIN INJECTION:no
NITROUS:no
AIR FILTER AND AIR INTAKE:stock
TIRE DESIGN, SIZE & AIR PRESSURE:26x11.5x16 ET Streets@20#
AIR BAG(s):no
SUSPENSION:stock
SCAN TOOL:none
FUEL:93 octane
CHIP:Thrasher Blue Tops
CHIP TIMING:??
KNOCK RETARD:??
OXYGEN SENSOR VOLTAGE:???
EXHAUST GAS TEMPERATURE:???
TRACK ELEVATION:Long Island Motorsports Park(near sea level)
TEMPERATURE:???
PEAK BOOST:stock(16.5?)
BOOST AT LAUNCH:5 psi
MILES ON THE CAR/ENGINE:50,000
This was the first time I went to the track with this car,I went again to E-Town to try for 12's but the fuel pump started going away.
Steve
Be Careful....The TTA Owner's Union has set a limit of THREE TTA's per owner ;)
