Trade my 94 Camaro with 6.0L Motor for GN
TTA
1994 Camaro Z28 (6.0 Liter)
Engine:
2003 6.0L LQ4 (LS1) truck engine with about 30k miles !!!
Stock 317 Alum Heads
Ported 75mm TB
186* Thermostat
K&N Filter
255lph Fuel Pump
30lb per/hr Injectors
10w 30 Synthetic Oil Only
The LQ4 engine for 2003 puts out 325HP and 370 Torque as listed here. These iron blocks are very popular and super strong, they are widely used for supercharging, turbo or nitrous applications. It has a 2000 PCM with a very modified 2002 Camaro SS tune for the 6L Motor. Tuned with 'HP Tuners' by George Lara at Jenibella Racing
Transmission:
Built 4L60e Auto Trans (Less than 600 miles since built)
Yank SS4200 Stall Converter with lock-up
Shift Kit
Billet Servo's
Kevlar Band
Alto Clutches
Sun Shell
TCI Trans Cooler
Rearend:
10-Bolt rear with 2.73 gears and Trackloc Posi
Exhaust:
Hooker Shorty smog-legal Headers into 3" y-pipe then Bung welded-in after y-pipe so it's ready for your Wideband Air/Fuel o2 sensor, then goes into NEW single 3-way Cat then into huge 4" pipe & Muffler (rear o2's deleted). Sounds Awesome!!!!
Suspension:
QA1 (R's) 12 way adj. Coil Over 90-10 Drag Shocks up front with Eibach Drag Launch Springs
KYB AGX 8-Way adj. shocks in rear
Spohn adjustable Rear Lower Control Arms
Spohn adjustable Torque Arm with Driveshaft Safety Loop
Front & Rear Swaybars
Poly Bushings
Subframe Connectors
Tires / Wheels:
16x8 Wheels & Toyo 245-50/16 tires all the way around (excellent tread)
Other info:
1997 30th Anniversary grey cloth front seats
Harwood Black Fiberglass Cowl Hood (uses OEM hinges and latch assembly, so it works just like a stock hood)
AM-FM CD player
Power Steering
Power Brakes
Power Windows
Power Door Locks
Power Mirrors
Rear Window Tint
No A/C, Heater, ABS or Traction Control
CLEAN CALIFORNIA TITLE IN MY NAME. Passed smog on 12/20/06 legally!!! (SMOG CERT IS GOOD FOR 90 DAYS FROM 12/20/06) Adult owned, not abused. Speedo shows about 124k miles
Car has gone 8.14 @ 85.53 MPH, 1.851 60' in 1/8 mile
For more info call: 626-347-0713
Located in Monrovia, CA 91016
Email: sra@usa.net
I am asking only $6500 firm for this car or trade for ???
