Justin Wray
- Nov 12, 2004
Well, I just fragged the 700R-4 and converter in my 1970 Chevelle. I'm a little torn as to whether I should rebuild/replace what I already have, which by all accounts should be cheaper, or "upgrade" to a 200-4R.
I'm pretty familiar as to what needs to be done conversion-wise, but was curious as to which builders/companies you guys like for the 200 trannies and converters.
The specs, etc.:
1970 Chevelle 3540 lbs. w/driver and a full tank of gas.
355cid small block Chevy w/ approximately 435hp/400ft. lbs. tq. at the flywheel.
3.91 gears in a 12-bolt Posi rear.
28" tall tires.
My intended usage will be for a daily driver come next March (as I have no other alternatives at this time), but an OCCASIONAL trip to the track over the next 2 years. After that, hopefully I'll have more opportunity to get more track time and she won't be a daily ride anymore.
My previous best E.T. was 8.36 in the 1/8th on the brakes. I've done several things to improve the combo since then and feel that she should be a solid mid-12 second combo (I know...nothing for you Buick GN boys
)with more seat time. I don't want to sacrifice much in the ways of performance, but I'd like something that is dead reliable (when set up properly of course).
My previous converter was a 10" custom NON-LOCKUP piece that flashed to 3500 or so. It felt good. However, I'd like to try a LOCK-UP this time around if it would work for my application.
So, short story long, I've started to check around. Bow-Tie Overdrives has a Stage 3 200-4R tranny for $1284. Other incidentals, such as flywheel, flywheel cover, converter lockup kit, dipstick tube, cooler lines, TV cable kit, throttle bracket and installation kit run about $500 total. That gets me for about $1800 total without a converter. However, it's a pretty thorough kit that would give me some piece of mind.
Does anyone offer anything competitive like that? Anyone ever deal with BowTie Overdrives or some of the other performance tranny places? $1800, again without a converter, is a huge chunk of change for this guy to swallow, but I put right at $1000 into this 700R-4 and custom converter that only lasted 2-3 years and ~2000 miles. :sad:
If it makes any difference, I could get a core 200-4R at a local yard around here for $10-20. However, I don't really trust any of the local builders. It would have to be sent off for a good build. Would having my own core put me ahead any at all?
Thanks for any and all help. This is my first post, btw.....
The specs, etc.:
28" tall tires.
