Tranny Brake Removal
DAVID C
How hard is it to remove my stageright tranny brake? I didn't install it. I do have the original valve. I get nervous thinking about the valve body and those little check balls. Also, the instructions that came with it are sooo dark, you can't make out the pictures. Is there a hole that needs to be plugged? If so, how? Dave C.
Trans
Is it a 200r4 trans or a 400 bop?If its a 400 i will probley buy it from you when you get it out.Sorry i dont have a answer to your question.Iam sure someone will help you out.
