tranny broke?
cutt
stalled up then no reverse,no neutral and in park it feels like its stuck in between just binding up
sounds like the forward clutches are stuck / burned to the forward ring gear.this will give no reverse and creepin in all ranges including park when hitting the pedal .does it pull forward in neutral and park,or try to?if so the only remedy is a rebuild.
