Tranny Fittings !!!!!!
boost86
Hey guys Im looking to buy a tranny cooler from summitt today and was wanting to put it infront of the ac. So what i was wanting to know what size fittings I would need for stock lines. If any one could help that would be great thanks.
Also summit part number would be great !!!!
Tranny cooler BMM 70268 11'' X 7.5'' X 3/4''
Transmission Fittings
Are 1/4 npt thread male on case side and #5 inverted flair female on the other. You will need adapters from 1/2npt to 1/8th pipe and then a fitting that goes from 1/8th inch pipe to #5 inverted flair to accept your stock line fittings. .
Any GOOD hardware store or hydraulic parts store should stock. If not, give us a holler as we have many.
Mark
www.PTSXTREME.com
Boost, I would be happy to send you some, but by the time you get thru with shipping and the parts, you will be paying about 5 times what you could pick them up for at A Lowe's or Home Depot.
You may even try an Orchard if you guys hvae them there.
boost86, here are some Summit part #'s to run braided line from tranny to new Summit cooler part # prm-2315. 20 ft braided hose part# sum230620 {6an}, 2 male connectors#sum220647 {6an-1/4 pipe}, 2 male connectors # sum 220648 6an 3/8 pipe, 1 straight hose end #sum-220690 6an, 2-90* hose end #sum220687 6an, 1 45* hose end #220686 6an. Total costs 245.68. HTH. :D
how bout if you wanted to keep stock lines any help??
