Tranny fluid leaking from converter area
G-Force
Right under the torque converter is where it is leaking. Any idea what it could be. Is there a gasket that prolly gone bad? Any idea? Would appreciate any and all help. Thanks.
The most common places for a transmission to leak up front are the front converter hub seal or around the perimeter of the pump housing itself. That juncture is sealed with both a paper gasket and a rubber o-ring.
Less common is a leak in the converter itself such as through a weld.
Sure it's not the front edge of the pan gasket?
Trans pan maybe leaking as well. here is always fluid on the pan bolts dripping or maybe it is coming from the seal you mentioned. I will try and get anew pan see if that helps.
