Tranny Temp Sensor?
85TurboTtype
It's just a V6!!!!
Is there an easy way to hook up a temp sensor for the tranny? If not what is required to hook one up? I think that this would be a good idea to have one of these....correct?
Thanks,
Matt
I have heard people say that they monitor their tran temp. I sure would like to see what the temp the fluid is running alos. I just installed the B&M supercooler. Where would a sending unit go in the system?
Mine is in the line near radiator. Noticed a 20-30 deg drop in temp
after trans cooler install.
Turbofrank - a 20-30 degree drop from what temp?
Conected near the radiator ... on the line coming from the engine or the line after the coolers?
John
Trans temp normally mimics eng temp. My temp is around 170-185.
Temp sending unit in tranny line near radiator.
On a cold day lets say 45 or below trans temp reads about 120-100
