Trans brake electric hook up
pokerbrat
Curious if this is where I wire electrical for electric trans brake, green connection on drivers side of transmission
Previous owner said trans has electric trans brake just not hooked up
If it's a Extreme Automatics brake: put the car in 1st gear and hit either of the terminals with 12volts. There's only two so 50:50 chance then you will know for certain. The only other way which is messy: take the pan off trace the wire from brake solenoid to terminal.
War wagon nailed it
But...
I would throw it out there that leaving on the tbrake is very hard on the 200.
So if you dont need it to 60ft than you can do without it.
Thanks, ya I'm not sure whose brake it is I've had a transbrake before so I get 200 might not last lol
Thanks again will try the volt way first
That also looks like the electronic kick down switch on 400 turbo. Maybe they used that for the trans brake somehow? I would think you would loose the kickdown option if they did that.
Ya it is a fully built trans from ck performance supposed to have an electrical for the lockup as well,, not sure if that switch controls both, I'll check the 12 volts first for the trans brake
