trans cooler line bracket
vader6
Turbo Buick enthusiast
Folks,
I am hoping someone can send me a picture from a real vehicle that shows the bracket holding the trans cooler lines -- the one that mounts to the oil pan. It would be "part 4" on the attached diagram. Also, what is the correct dimension of the stud that mounts the bracket to the pan? Thanks!!
Years ago we found the trans line bracket was an issue as it tends to move in the bracket which will result in a leak in the trans fluid line.
I just trashed a bracket last week, and never use them.
If you want to secure the lines, us a 2" piece of rubber hose split to fit over one line and tie-wrap the lines together.
thanks for the advice Nick!!
