Trans Cooler
BILL HAINES
R.C ENTOURAGE
I Am Installing A Trans Cooler On My Car. I Purchased Actual Gnx Cooler Brackets,i Purchased A Gm Accessory Cooler Assy. The Cooler Kit Directions Say It Is For A 81-87 Chev Full Size P/up Or Blazer. I Looks Identical To The Gnx Type Trans Cooler. (aux Engine Oil Kit Pt #997033) I Bolts And Lines Up Perfectly I Guess What Scares Me Is The Description "aux Engine Oil Cooler" Also If I Turn It Upside Down,it Sounds Like The Outside Fins Are Loose??? Maby Some Sort Of Check Ball??? Any Advice Or Ideas????? I'm Sure Rick Hunt Could Chime In....
