Trans fittings
Buicksx2
RCA: Home of the The Jack
Hi All,
What size fittings do I need to run steel braided lines from trans, need the AN size fitting and what size fitting will fit into brass fittings on stock radiator to make it complete?
Also are the same size AN fittings on a 200r4 the same as on a 400 trans?
Thanks in advance
For the transmission, you'll need -6 AN to 1/4" pipe adapters. Not sure about the radiator though. My GN has braided line from the transmission directly to the TCI transmission cooler that is built with AN fittings. I bypassed the radiator.
