Trans line to radiator measurements?
nero
Ran into a problem installing this beautiful radiator from GBP; the top trans line on the stocker won't come out the fitting. Not with PB blaster or a tube/line wrench.
I'm wondering what the measurements are or what I need to buy (AN conversion if necessary) to make a new line.
The bottom trans line to radiator is fine.
Thanks in advance
Why don't you bypass the radiator trans cooler, and install an auxilliary trans cooler?
I'd still need lines, or no? The lines coming out the trans are A-OK, but the top line from the radiator is the problem. Can I just leave the radiator fittings open and what do I do from there? I don't fancy digging at the trans lines... can they still be used?
Part numbers and help on that please, sir.
:-D
Cheers
Plug rad fittings or leave open. Cut end of trans line and buy rubber trans hose to go to external trans cooler.
That's ingenius! What size hoses fit over the trans lines?
Your Choice
I just replaced my old clogged radiator with a NOS one. The trans lines were a nightmare. The old ones came off easily enough by heating with a torch (I was later told trans fluid was flammable). Although my car has a separate trans cooler I wanted to keep it stock so I reinstalled them. Easy enough but they leaked. So I pulled the radiator again and tightened them. Still leaked. So I pulled the radiator again (getting good at it by this time...drained, out, tightened flare fitting, back in, in only 40 minutes), and still leaked. By the fouth time, I must have had 100 ft/lbs on the fitting (something I really hadn't planned on doing with brass) and they finally stopped leaking. Guess this is why they are so tough getting off.
Brian at G Body Parts has both the 90 degree fitting and the tubing if you want to go that way. If I had a choice, just go with the external cooler.
Thanks guys, I have an external cooler from Advance by Imperial (a Hayden company which also makes B&M). I have to cut the flared fitting off the trans line coming from the tranny, best tool to do that? I need to do it so I can attach the rubber hose to the line to the external cooler. Do I need to plug the rad tranny cooler line holes or can I just forget 'em and leave 'em open?
A clamp behind a small flare is good to keep the hose from sliding off.
I would use a tubing cutter. Any "saw type" of tool will put allot of metal flake in the line.
