Trans pan spacer to use 700R4 filter
orangecar
Anybody use the trans pan spacer that sets the stock pan down a little so the 700R4 filter,with the bottom intake ,will clear, does it work ok for a street car, to make sure the trans has good oil supply on hard acceleration. thanks
I've never seen the pan spacer. I am running a deep pan from DRW. They cut the rests inside the pan so you can use the 700 filter. The pan is only 3/4" to 1" lower than stock.
It works fine. Ive used a few different cars with no problem.
