SignUp Now!Originally posted by 2quiktocare
I wouldn't call them junk, it is if you have the money, the electric brakes are the best way to go. Also you dont have to deal with the rebound from shocking the sprague like the stage right does on many hard launches. I personally would never think of selling a 200 4R without an improved sprague in it for anything that looks at under 13 second times.
Originally posted by buickboy
I understand from my trans builder that if someone could design a sprag and surrounding parts to work with more sprag elements that it could take the load much better. To my knowledge, no one does make one for a 200.
Mitch
I was told by jimmys trans that trans brakes are bad on the tranny for reason of people useing it to build boost at the tranny weak spot of the 3 gear band not to queston his opinon but I would love to use a trans brake if it will not kill my trannyOriginally posted by 2quiktocare
The Stage right brake when released shocks and loads the sprague. The electric brakes such as ours and the one Chris sells does not load the sprague. We both use the clutches to lock the trans. This avoids the shock and damage to the sprague when unloading all that power. The up front cost may be more, but the reliability and the savings in not blowing out the sprague is worth it.
thanks for replyOriginally posted by Intercooler
It's racing! Things are going to break. A trans-brake is hard on parts so if it isn't your cup of tea just pass on it and use the foot-brake.
thanks for replyOriginally posted by KLHAMMETT
WEll the transbrake doesnt use a 3rd gear band,As there is no 3rd gear band,But it does use the 3rd gear(or direct) clutch,It does wear a bit, but only when it releases and just drags for an instant(thats if the trans is built correctly),The clutches in my expierience dont take the abuse,But forward drum,od planet,od ring gear,and input shaft. I have broke them all at one time and had replaced them with billet peices.
But i sold my 2004rs and Built myself a 400 and never is it in my mind that it may break,I know it can,But i dont worry about it,With the 200 every time i released the brake,there was always the thought of something breaking.
