Ive got the chip dialed in decently, about 22 deg of timing with about 26 lbs of boost. It runs great except from highway speed or anything near that if I just gun it. It will kick down and i will get instant knock.
Clearly, the alky is not reacting fast enough to the sudden jump in boost.
I thought of several ways of correcting this, but none of them are easy. Maybe a code patch that retards the timing relative to speed and change in throttle position that decays out, kinda like a pump shot
or maybe some sort of trigger for the alky using the same criteria
Any ideas?
ive adjusted the turn on point and initial to start very early (like 0 psi) and come on strong right off the bat but its still too slow to react
btw ive got it hovering around 11.5:1 afr on the wide band, and egts are extremely low (seems odd, but its been that way since i switched to methanol, even when I started tuning and it was way on the lean side due to the much richer stoich methanol has over isopropyl)
Any ideas?
