Translator+ and spark question
dsa87gn
I was reading up on my not yet installed t+. There are independant settings for SPARK BASE and SPARK WOT.
I am assuming then at WOT the BASE figure will be ignored and the WOT value used.
Say I have SPARK BASE on 4 Degress advanced and WOT at 2 degrees advanced. Then at WOT I would only get the 2 degrees,
not the sum of base + WOT (6). Is this correct ?
You will get 6.The wot is added to whatever the base is set at.If you set base at 4* advanced and want it advanced only 2* at wot,you would set base 4* adv and wot 2* ret.
