[Dave] "The Beautiful part of the Translator Pro/Extender Pro system is that Bob Bailey has absolutely nailed the Turbo Regal setup so that startup and run in is seamless!!"
Thanks, Dave. So, I ditch the MAF and splice in a few wires. Then, I buy a high boost modulator and wire it in.  I already have a WB O2 for the LM-1.  Is it as simple as using the WB O2 and MAP to drive the T/Pro? Does it really start and run decent at the get go?  We have pretty limited nice weather up here in the Pacific NW, so I don't want to spend another 2 week summer trying to dial-in a new gismo. I'm not afraid of tuning, but I'm almost ready to rock and roll now and hate to start something new in late March.  I'd so much love to ditch the MAF, though.
When I first installed mine all I had was the stock NBO2 sensor. So, for the ease of installation, I also forked over for a plug-n-play adapter.
Yes, my car started and ran perfectly upon completion of the install.
Will that be the same for every car? Probably not, since there are infinite numbers of combinations available, some more bizarre than others.  We call that a leap of faith.
  Mine is  a simple combo. MSD50's, TE44, V2.  That's it. The more radical the cam, heads, and larger injectors, the tune is a little harder. Not terrible though. Nothing as complex or difficult as a stand alone speed density system!!
I plugged in the TPro, unplugged and removed the maf. Kicked the tires and lit the fires.
Fast forward to a couple months ago. I received a WBO2 for Christmas (thanks to my loving family). So, got it wired in (didn't need a gauge because I monitor WBO2 via Scanmaster/Powerlogger). Didn't have to make many changes in the user tune tables to get the A/F ratios where I want.
But, to make things easier, you may or may not need to do some tweeking in the user tune tables to at least get your A/F ratios in the ballpark, and then...
You can turn on WBO2 "tracking" and your WB will do the rest. Not only WOT but also PTT (part throttle tracking) which cover idle up to WOT.
