Transmission Cooler Lines
trans. lines
Buy you some mild steel tubing from a parts store and a cheap bender and make your own.It is a very cheap and easy way of repair..Just remove the starter for room to work around and take a clothes hanger to make a pattern for the tube.The line does not have to one piece from the rad. to the trans.You can use good fuel line hose at any point,just use double clamps on both ends of hose..The line size is 5/16 & the fuel line is 5/16..You can do this for less than 30.00 bucks..Just take you time with the bends..
