Transmission COOLER
turbojkt
Has anyone got a recommendation for the best Trans Cooler. How big? With a fan or without? Any suggestions would be appreciated.
Can't remember the brand, but I bought a heavy duty RV cooler at Autozone that seems to work well. When I had my tranny redone, I had a trans temp gauge installed, and the temp runs around 160 to 180 degrees on the highway and depending on the outside temp. The trans cooler is mounted up front of the AC radiator, and the trans cooler in the radiator is bypassed/not used. I do have the dual fans which may help pull air through it. I have a small 9" non-lockup torque convertor, so it should be creating quite a bit of heat.
B&M stacked plate coolers. #70255 is the one i have but you can go bigger. They make some of the BEST coolers around and are reasonably priced as well. I think i only paid $49 at Summit.
