Transmission factory cooler line thread size
85tr
I am installing a transmission cooler and bypassing the factory cooler as I grenaded my last trans and am installing a rebuilt one. I was curious if anyone knew the size of the factory cooler lines so I can pick up a few barbed fittings to run lines to the new cooler. Thanks.
I would like to know as well. What fitting will screw into the factory lines right next to the radiator so I can plumb it
Believe it is a 1/4" NPT out of the cooler and and transmission lines use 5/16" inverted flare fittings
