Transmission mounting locations on frame?
6pack
T-Time
Ok are there supposed to be two mounting locations on the passenger side or driver side? I have 2 on the driver side and only 1 on the passenger side...is this correct?:confused:
Hi,
there are two on the driver side and one on the passenger side.the new crossmemeber you will be getting will mount on the foward most spot on the driver side and use the same location as the 200r4 crossmember on the passenger side.if the crossmember is out of a car that had a v6 it will use the same mount as the 200r4.if the crossmember came out of a v8 car it will use a th350 mount.i have a th350 in my car also.i love it.
nick,
