SignUp Now!WE4 said:In fact, we use a reducer bushing to accept 1/8th pipe and you have 1/4 pipe so it will fit just fine.
Mark will be emailing you here shortly.
Bruce
We4
www.PTSXTREME.com
WE4 said:It is stagnent oil there. Just pressure. It does not see the true temp that is being discharged out of the converter. The oil at the PRESSURE port is stagnent. meaning, it is just trapped there off the manual valve and pump cavity. The temp you want to KNOW is what is being discharged out of the converter and returning from the cooler.
Hope this makes sense.
If not, contact me for further explanation. It is important you understand this principal.
Install as we suggested and you cannot go wrong.
Bruce
WE4
www.PTSXTREME.com
