O.K.
84ZZ4,
Feeling mighty confused about those figures you wrote about I went and found known gear ratios for the THM-350,
http://www.montecarloss.com/SSThunder/drivetrain.htmland). I plugged these figures into a transmission gear program I got. Here's what it came up with:
1st gear shift point is at 23.5 MPH
2nd gear shift point is at 39.40 MPH
3rd gear shift point is at 59.60 MPH
Tire size, (R-14's), and rear gear ratio, (2.41), are contributing factors and yes, all these shift points are below the 2000 RPM range. Pretty surprising
. No wonder launch sucks in these cars, look at the huge leap it has to travel just to shift into 1st gear!
Yep, I was wrong with the 15 MPH for first gear. But at 25 and 50 MPH these are definate 1st and third shifts on my car. I'll have to double check at 39 mph to verify the final 2nd shift estimate.
Lock-up is easy to verify but can trick one into believing its a shift change if on does'nt have an OTC moniter like I do. On another thread I posted, (
.....Idea), I gave a nifty trick on verifying lock-up....check it out!
