TRC Turbo Protector
I've got it and like it, I've yet to replace the filter in it but will next year. I like the fact that it's small and I would easily use a -3 fitting with my Brake Line Oil Feed turbo setup.
I like mine
I got the one without the turbo feed, the pressure drop is so low with these, that the bypass in the oil pump should never open (the reason for the separate feed).
It is a very nice piece, for sure.
Bob
Wow, $120 for a new filter at the link the OP posted! Can you use a less expensive filter with that kit?
Thanks for pointing that out. :smile: Now it seems like a pretty good investment.
