turbojimmy
Supporting Member
- May 26, 2001
Hi all,
I took my turbo off to port the wastegate. I've always had a leak over there but I'm not sure where it is. I thought maybe it was the turbo-to-header, but now I'm not so sure. I used some copper sealant (spray kind) on it and I can still hear a leak. I have a copper gasket as well as some Coppercoat brush-on sealant (thicker than the spray stuff) on the way but I'd like to avoid putting a gasket there unless I'm sure that's where the leak is.
I tried using a piece of heater hose up to my ear but can't pinpoint the leak. It's either the RH header, the turbo-to-header, or the downpipe. It's got to be affecting spool, too. The PT51 is a bit lazy off the line despite a high stall converter.
On the upside, my porting worked well. Seems to be sealing okay and boost is rock solid where I set it. I don't have to constantly watch the boost gauge now. It was creeping up *fast* before.
TIA,
Jim
TIA,
Jim
