trouble codes w/DS
Dwayne
Narrow A$$ Racing
I have 3 codes that appear on my car with DS, they are as follows;
24 - vehicle speed sensor
42 - est monitor error
55 - ecm analog/digital convertor failure
My questions are;
can these codes be cleared from the DS?
I can unplug the ecm hot wire to clear the ecm, but the moment I plug the DS in to the ecm I get these codes.
I took the car to the track last night and it seemed like the car lost all power as if you shut the key off for a split second. The battery volts stayed above 13.5 volts all the time. I have changed everything....plugs,wires,coilpacks you name it.
Can someone enlighten me on these trouble codes...thanks for the help.Dwayne
Sounds like something in your DS hookup is causing the codes. Might be ignition noise, grounding or the connector on the ECM.
