- May 29, 2001
Yup, it should do the same!
It's a bit easier to test...
turn the crank until the until the trigger wheel "vane" is within the crank sensor tabs, then take a voltage measurement...
then move the crank so NO vane is between the tabs, then take another measurement.
I'm not sure which is which, but ONE reading should be from 5 to 12 volts, the other from 0-2 volts.
My thinking is, if BOTH sensors voltage test badly, then it may be the ignition module you need to look at(?) It's hard to believe both sensors would go bad at the same time! (unless some sort of electric problem fried 'em?)
I have a full-blown flowchart from GM that goes thru step-by-step to troubleshoot a no-start problem, but I can't get it to scan decently, and I haven't found time to duplicate it...I'd really like to get it on the internet, because it makes more sense than I do!
![Wink ;) ;)](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f609.png)
