I'm trying to get a 12V source to four 30 amp relays mounted in the trunk (3 fans and an external fuel pump). Which wire or wires carry a 12V signal in the trunk? Can I tie all 4 12-volt relay wires into one and feed it to one single 12V source wire?
Also which wire is used for the factory fuel tank sending unit signal that goes to the fuel gauge in the dash? I want to connect my fuel cell sender to my fuel gauge in the dash (so I know how much fuel I have). It is a 0-90 ohm sender.
