After trying different mixtures/settings etc with the alky/h2o injection over the years, I have never been able to really utilize it like I wanted/or should. Part of the reason is that I had been chasing down other problems and so I would usually leave the alky turned off. Yesterday I finally remembered why I put the kit together in the first place....... to serve as an intercooler (remember this is a Hotair car). I went ahead and filled the tank with straight distilled h2o, installed the largest jet I had (.040), and hit the streets. Not sure why I went with that jet since I had usually used a smaller one before with the alky(.025 I think), but something just made me do it. I think I was wondering if my thinking was all wrong in the past with the smaller jet and that atomization would actually be better with a larger one. Anyway, turn on was lower than I meant to set it, at 8psi, but to my surprise I had relatively no bogging issues. The car ran great. I adjusted the turn on up a bit to 10-11psi and later on hit the highway with Tlink.
I made three runs, punching it from about 50-90mph. Keep in mind just a few days ago I was having trouble running over 15psi w/o 4-8deg KR. Also note* that boost amts are from Tlink and may actually be 1.5~psi greater (according to vdo gauge). readings are in 3rd gear (43psi FP, 93oct).
1st run:max boost hit 15.6psi* w/ 777 O2s & 0 KR
2nd run: FUSE BLEW FOR PUMP AND DIDNT KNOW!! (apparently wasnt using high enough amp fuse). I had turned the boost up 1 full turn on the WG for this run since I had no KR on 1st run. Max boost hit 14.8psi* w/ 812 O2s & 4 deg KR
3rd run: FIXED FUSE ISSUE WITH H2O INJ. Went ahead and turned boost up 1 more full turn on WG. Max boost was 18.2psi* w/ 762 O2s & 2deg KR (most of the run was 0 KR)
Okay, the H2O is definately working as a intercooler for me (right?). I was able to successfully run at least 5lbs more boost than a few days ago without KR. The issue with the fuse blowing was not a bad thing for testing either. Notice on that run that I turned the boost up but the #s went down 1~ psi from the previous run! So, the air charge must be more cool/dense with the H2O, right?
I also noticed that with the H2O, although KR was not an issue, the O2 #s went down
. Also, during the run w/o injection the car felt like it was hauling ass a bit more than the other two runs. On all three runs I was WOT for about 8 frames on Tlink. On the H2O injection runs MPH was around 90 in the 8th frame, while the injection-less run was at 98 mph in the 8th frame! These are the issues that concern me, and would like to have some insight on. I feel that I am definately getting somewhere here. I could up the turn on point higher, but not sure its a big deal or not. + wouldnt it be a benefit if I could keep it coming on early to actually work as a intercooler? I could also try dropping the jet size down to .035. Or, is this the time to start adding alky back in, maybe 25% to 40% to start. I was thinking of trying Methanol this time around if it comes to that. Maybe I should dial more boost in? Fuel pressure?
The effects that H2O alone are having is kind of intriguing me though (the fact that it is cheap aint bad too). I was hitting the car up this morning on my way to work and hit 20psi boost w/ no signs of KR.
Thanks for any help or insight you guys can offer.
P.S. Just wanted to note that the pump Im using is a F150 inline pump (90psi rating), and sorry for such a long post guys!
