8
		8UWITH6
Guest
HI guys,
As you can see in my signiture below, my GN is running fairly well. That time below was done last weekend on my 16" Nitto Drag Radials. Im very pleased with how the car is running and the times, but I KNOW there is a lot more left in it. To fill you in on basic mods, the car has:
ENGINE:
Stock Turbo and IC
Blue Tops
3" MM DP, stock ported elbow
Hooker cat back
Comp Cams 206/206, springs, lifters, chain and gear, etc
Upgraded fuel system
14" K&N with cold air
TRANS:
Stock that I know of, stock D5, getting sloppy
REAR/SUSP:
Snubber
Air bags (which I dont really use)
Front bar unhooked
Otherwise stock, I know I need shocks soon
So, now that you have an idea of my setup, specifics are that this particular time to the track, I was running 110 octane turbo blue fuel with a Jay Carter 110 race chip. Boost was set to 20, slight creep to 21 in 3rd gear. Static FP was 43. 02s down the track where 800s most if the way that I saw, and according to Scanmaster the lowest was 792 at 105mph on the recall, no KR at all.
Now, Im very happy with my ET and MPH, although I was hoping for 110 mph. The place Im hurting at is getting out of the hole. My 60fts have been ranging from 1.9x to 2.0X the past 2 times to the track. (5 total passes). The tires have about 10 good passes on them, burning the hell out of them every time. My best 60ft with my nittos is 1.92, which IMO isnt good. Im leaving the line anywhere from 2 to 5 psi of boost depending on the track. When Im ready to let go I lift the brake and stomp the throttle immediatly, and the car feels GREAT leaving, spools fast, etc. But the proof isnt there. Occasionally Ill get a SLIGHT amount of spin from the tires about 20 feet out, which I do know hurts the 60ft, but its not spinning long AT ALL. The times it doesnt spin is when I leave at 3psi or less......I honestly dont always look at the boost guage, I just do it by feel. When I "baby" it out of the hole I still get 2.0X 60ft times. I was hoping for 1.8s or even 1.7s??? Where are they?? Do you see anything wrong with my tune/combo?? The car feels GREAT finally.....I just want some 12.40s and 110-112 mph if possible.
Things I have thought about doing:
Turning up the boost another pound to lean it out some more, but Im kinda chicken
1psi less FP to possibly lean it out
Rear shocks
Uncapping the exhaust
Different chips
I appreciate any help/opinions you can give me, thank you in advance.
Sorry for the long topic
ENGINE:
Stock Turbo and IC
Blue Tops
Hooker cat back
TRANS:
REAR/SUSP:
Snubber
Front bar unhooked
Rear shocks
Different chips
