John Pearcy
- Jun 21, 2001
This TT/A is motor is remanufacturered to OEM Specs with .030 pistons. The engine comes just about as drop in, turn key as it can get, if your doing an F-body conversion, it's all here. Motor mounts and plates, dipstick tube, fuel rail with the lines and special brackets, vacuum block and lines, complete oil cooler system, Wastegate solenoid with bracket, EGR solenoid with bracket, EGR valve with clamp and molded vacuum hoses, Coilpack bracket, Alt and A/C brackets, main accessory bracket, Crank sensor and bracket, turbo feed line with brass block, even has the vacuum hose with the check valve to the vapor canister.
Engine does "not" include a turbo, exhaust crossover pipe, Temp sensor, fan temp switch, knock sensor and coolant temp switch, plenum and T-body.
Price is 6K, Frieght to anywhere in the 48 States is included in the price.
