TT/Ameasap
The White Blur
- Jan 31, 2002
Details of the run:
60'--1.73
330'--5.013
1/8--7.673
MPH--91.64
1000'--9.993
1/4--11.946
MPH--113.07
Screen Name or Car Number Here
EMPTY WEIGHT:stock
BLOCK:stock
HEADS:stock unported
CAM:stock
TRANSMISSION:stock
TORQUE CONVERTER:stock,restalled2800
DIFFERENTIAL:stock
INTERCOOLER:stock
THROTTLE BODY:stock
RJC POWER PLATE:yes
INJECTORS:50#
THERMOSTAT:170?
TURBOCHARGER:TA-49
VALVE SPRINGS:100#
MAF:stock
DOWN PIPE:THDP
EXHAUST:edelbrock
FUEL PUMP:Walboro 340
FUEL PRESSURE REGULATOR:billit
FUEL PRESSURE:39psi
ALCHOHOL INJECTION:Razor's PAC system
PROPAIN INJECTION:no
NITROUS:no
AIR FILTER AND AIR INTAKE:K&N
TIRE DESIGN, SIZE & AIR PRESSURE:M&H racemaster 11.5x16x26@16psi
AIR BAG(s):no
SUSPENSION:stock
SCAN TOOL:Scanmaster
FUEL:93 octane
CHIP:Eric Marchall 5.3
CHIP TIMING:23in 1st and 2nd and 20 in 3rd
KNOCK RETARD:0.0
OXYGEN SENSOR VOLTAGE:800
EXHAUST GAS TEMPERATURE:no EGT
TRACK ELEVATION:10 ft?
TEMPERATURE:90 degrees
PEAK BOOST:23.5
BOOST AT LAUNCH:8-10psi
MILES ON THE CAR/ENGINE:79K
My best MPH was 93.16 1/8th and 113.85 in the 1/4.On that run I ran 11.985.
I need more timing up top to get my mph up and I can go another couple psi on the boost of course. So, we will see what happens on the next outing.
Have to thank Julio for his awesome alky system and Eric Marshall for his awesome chip.
If you want to go fast........Get the alky and chip from these guys.
Bo
60'--1.73
330'--5.013
1/8--7.673
MPH--91.64
1000'--9.993
1/4--11.946
MPH--113.07
EMPTY WEIGHT:stock
BLOCK:stock
CAM:stock
TRANSMISSION:stock
DIFFERENTIAL:stock
INTERCOOLER:stock
THROTTLE BODY:stock
RJC POWER PLATE:yes
INJECTORS:50#
THERMOSTAT:170?
TURBOCHARGER:TA-49
VALVE SPRINGS:100#
MAF:stock
DOWN PIPE:THDP
EXHAUST:edelbrock
FUEL PRESSURE:39psi
NITROUS:no
AIR BAG(s):no
SUSPENSION:stock
FUEL:93 octane
KNOCK RETARD:0.0
PEAK BOOST:23.5
Bo
