TT/Ameasap
The White Blur
- Jan 31, 2002
Details of the run:
60'----1.998
330'----5.490
1/8---8.346
MPH---86.38
1000'---10.832
1/4---12.911
MPH---108.19
Screen Name or Car Number Here TT/Ameasap #1022
EMPTY WEIGHT:?
BLOCK:stock
HEADS:stock/ No porting
CAM:stock
TRANSMISSION:stock
TORQUE CONVERTER:stock
DIFFERENTIAL:stock
INTERCOOLER:stock
THROTTLE BODY:stock
RJC POWER PLATE:Yes
INJECTORS:50#
THERMOSTAT:160
TURBOCHARGER:TA-49
VALVE SPRINGS:100lb
MAF:stock
DOWN PIPE:3"Terry Houston
EXHAUST:3" Edelbrock
FUEL PUMP:Walboro 340
FUEL PRESSURE REGULATOR:billit Adj.
FUEL PRESSURE:45psi
ALCHOHOL INJECTION:No
PROPAIN INJECTION:No
NITROUS:No
AIR FILTER AND AIR INTAKE:K&N
TIRE DESIGN, SIZE & AIR PRESSURE:Fireston firehawks sz50, 245x50x16
AIR BAG(s):No
SUSPENSION:stock
SCAN TOOL:Scan Master II
FUEL:93 oct. Zylene
CHIP:Thrasher 92
CHIP TIMING:18?
KNOCK RETARD:0.0
OXYGEN SENSOR VOLTAGE:810-820
EXHAUST GAS TEMPERATURE:N/A
TRACK ELEVATION:10ft ?
TEMPERATURE:70 degrees
PEAK BOOST:18 psi
BOOST AT LAUNCH:2 psi
MILES ON THE CAR/ENGINE:79K
This was the first time out with this car. No tuning. All my tools were in the back including 12pack of pepsi behind my seat and converter wasnt locked. No spring cleaning yet and I left all tire pressure at a guess.
I prolly could have gone a little faster if I prepared to go, but I expected to spectate again. No GN's, No TR's or TTA's. So I was representing for the Turbo buick's .
Hope I can update this post again soon.
Bo
			60'----1.998
330'----5.490
1/8---8.346
MPH---86.38
1000'---10.832
1/4---12.911
MPH---108.19
EMPTY WEIGHT:?
BLOCK:stock
CAM:stock
TRANSMISSION:stock
DIFFERENTIAL:stock
INTERCOOLER:stock
THROTTLE BODY:stock
RJC POWER PLATE:Yes
INJECTORS:50#
THERMOSTAT:160
TURBOCHARGER:TA-49
VALVE SPRINGS:100lb
MAF:stock
FUEL PRESSURE:45psi
NITROUS:No
AIR BAG(s):No
SUSPENSION:stock
FUEL:93 oct. Zylene
CHIP:Thrasher 92
CHIP TIMING:18?
KNOCK RETARD:0.0
PEAK BOOST:18 psi
Bo
 I was hoping the usual TR and TTA crowd would show up but I still had a good time.
