TT chip?
SIXBANGR
mean old man
Do you use the a/c to adjust this chip? If so, how do you do it if you have no AC ?
You use a scan tool with your gas pedal and watch the LV8 and BLM to adjust it. Check turbotweak.com, he has instructions on adjusting it.
version 5.6(newest one) just uses the gas pedal and LV8 and BLM cells. what version do you have?
don't have one. wanted to make sure I could use it with out air. My old yaklin chip used the ac.
So how does it work without the ac?
In the event that someone else runs into the same problem? Mahalo!
With version 5.3 (i belive his one first programable chips he made) was you had to unplug the MAT by the air filter, then you go back inside and turn on the AC and then it'd cycle through the numbers. It was more of a pain to get out and unplug it, but that's what i had to do before i got my chip updated.
-Just describing that you did have to use the A/C years ago to program the chips.-
-Adam
