gnloyalty877
t'squick6
- Jul 15, 2007
Here's a run after adding fuel in parameter 1 to blm 135. I still don't understand why my injector duty cycle is that high for only 22-23lb's? Could it be that i need to check the double pumper hookups. I checked my fuel pressure and with the line off i set it at 43, in the boost it went to 65. Also i don't understand why my wideband isn't going into closed loop. I did everything it said to do on vortexbuicks.com. Any suggestions is appreciated.
