TT SD Chip
TT/Ameasap
The White Blur
Upgraded to the SD2 and really dont need this chip anymore. This was my gas chip to convert back to gas from E85. I ran it at the drag strip without any problems. Idles and drives great.
Here are the specs
#120lb injectors
Gas or E85... it has up to 33% fueling for E85
20/18
$100
I paid the full amount less than a year ago.
Any questions, lemme know
Here is a PDF of the instructions for any technical questions.
http://www.turbotweak.com/turbotweaksds.pdf
Wow, that is a good deal. I'm actually looking for one of these but I only have 79lbs injectors.
SD doesnt have the capability of tuning VE spark and fuel tables, although there are parameters that still adjust these. If your not looking to learn a ton about tuning then this would be a great chip for you. If your wanting a mini ''XFI'' and you want full control over everything, the SD2 is the way to go.
I havent even scratched the surface of the SD2 yet. Lots of learning.
Also consider, this chip was $207 and for a little more than the average used TT chip($60), you can have this chip for only $100.
