GTABurnout
- Mar 17, 2002
Details of the run:
60' - 1.753
330' - 5.000
1/8 - 7.678
MPH - 92.19
1000' - 9.978
1/4 - 11.921
MPH - 115.77
Turbo Trans Am #1457
EMPTY WEIGHT:3,500 w/driver
BLOCK:stock
HEADS:stock/ported
CAM:stock
TRANSMISSION:Built by AZ GN
TORQUE CONVERTER:9-11 3400 stall
DIFFERENTIAL:stock
INTERCOOLER:liquid to air (ATR)
THROTTLE BODY:stock
RJC POWER PLATE:yes
INJECTORS:MSD 50
THERMOSTAT: 160
TURBOCHARGER:TE-44
VALVE SPRINGS:LT1's
MAF:stock
DOWN PIPE:3" Mease
EXHAUST:Cut out open
FUEL PUMP:XP (I think)
FUEL PRESSURE REGULATOR:adj regulator
FUEL PRESSURE:43
ALCHOHOL INJECTION:Razors PAC kit
PROPAIN INJECTION:no
NITROUS:no
AIR FILTER AND AIR INTAKE:K&N with ATR pipe
TIRE DESIGN, SIZE & AIR PRESSURE:26x11.5x16 ET Streets@15#
AIR BAG(s):no
SUSPENSION:stock
SCAN TOOL:Scanmaster
FUEL:C16
CHIP:Max Effort 8 pos for 50's
CHIP TIMING:24?
KNOCK RETARD:0
OXYGEN SENSOR VOLTAGE: .780-.810
EXHAUST GAS TEMPERATURE:???
TRACK ELEVATION:3100 Feet SIR Tucson, AZ
TEMPERATURE:65
PEAK BOOST:No clue but the 20 psi guage was pointing down
BOOST AT LAUNCH:10-12 psi
MILES ON THE CAR/ENGINE:67,000
GOT IT!!!!!!!
This has been my goal for the last few months. Razors kit helped greatly, the car just pulls hard up top now. Best part of the day was puting the slicks in the back and driving home, while watching all the trailer cars with no mufflers watch with envy...
Thanks to any one who has helped me out and a major thanks to Razor for helping me with the kit.
Thanks,
Hunter
60' - 1.753
330' - 5.000
1/8 - 7.678
MPH - 92.19
1000' - 9.978
1/4 - 11.921
MPH - 115.77
BLOCK:stock
HEADS:stock/ported
CAM:stock
DIFFERENTIAL:stock
THROTTLE BODY:stock
RJC POWER PLATE:yes
INJECTORS:MSD 50
THERMOSTAT: 160
TURBOCHARGER:TE-44
VALVE SPRINGS:LT1's
MAF:stock
DOWN PIPE:3" Mease
FUEL PRESSURE:43
NITROUS:no
AIR BAG(s):no
SUSPENSION:stock
FUEL:C16
CHIP TIMING:24?
KNOCK RETARD:0
TEMPERATURE:65
GOT IT!!!!!!!
Thanks,
Hunter
