Well the engine is done, running, and has almost 600 miles on her so far. I recently got my turbo heat sheild back from the chrome plater. It is the cherry on top of the rebuild and now it not only runs like it has a new engine it looks like a new engine! I have a small issue with the stock flapper in my elbow but that will be taken care of soon. Once that is done she will start getting some boost. In addition I also put on an original TTA spoiler since mine was warped and severely cracked. Now I really have people scratching their heads when they see the odometer reading 201,598 miles.
The highlights of the engine build up consist of the following:
Rebuilt stock GN short block
Rebuilt heads w/LT1 springs, new valves, etc
50lb Injectors
212/212 Comp Cam
TE-44 Turbo
Custom ECM
RJC Power Plate
Poly Motor Mounts
Repaired and Reinforced exhaust manifolds
Various Billet and after market pipes
And MUCH more
Dont worry, I still have every stock part to put it all the way back to stock if I want to.
50lb Injectors
212/212 Comp Cam
TE-44 Turbo
Custom ECM
RJC Power Plate
Poly Motor Mounts
And MUCH more
