Details of the run:
60' 1.53
330'
1/8
MPH
1000'
1/4 11.62
MPH 112
Screen Name or Car Number Here idaho gn/#871
EMPTY WEIGHT:3565
BLOCK:109
HEADS:stock
CAM:206/206
TRANSMISSION:len (lasvegas) performance transmission 2004r
TORQUE CONVERTER:tcs 9x11 3500 stall
DIFFERENTIAL:stock
INTERCOOLER:dequick front mount
THROTTLE BODY:stock
RJC POWER PLATE:yes
INJECTORS:#55
THERMOSTAT:stock
TURBOCHARGER:turbonetics t-72 bb p trim external wg
VALVE SPRINGS: stock
MAF:z06 and trnslator
DOWN PIPE:custom made 3 inch dp by qualifab inc
EXHAUST: atr w/ crossflow muffler
FUEL PUMP:340
FUEL PRESSURE REGULATOR:red armstrong
FUEL PRESSURE:40 psi line off
ALCHOHOL INJECTION:hate it
PROPAIN INJECTION:never tried it
NITROUS:are you crazy?
AIR FILTER AND AIR INTAKE:4 inch inlet w/3-7/8 k&n
TIRE DESIGN, SIZE & AIR PRESSURE: hoosire qtp 26x11.5x15 on 10 inch wide convo pros
AIR BAG(s):nope
SUSPENSION:bone stock
SCAN TOOL:direct scan
FUEL:trick 110 leaded
CHIP
te
CHIP TIMING:26 deg
KNOCK RETARD:none
OXYGEN SENSOR VOLTAGE:.787
EXHAUST GAS TEMPERATURE:na
TRACK ELEVATION:2800 ft air was at 6500 ft
TEMPERATURE: 98
PEAK BOOST:22
BOOST AT LAUNCH:22
MILES ON THE CAR/ENGINE:196345.3/56000
60' 1.53
330'
1/8
MPH
1000'
1/4 11.62
MPH 112
EMPTY WEIGHT:3565
BLOCK:109
HEADS:stock
CAM:206/206
DIFFERENTIAL:stock
THROTTLE BODY:stock
RJC POWER PLATE:yes
INJECTORS:#55
THERMOSTAT:stock
FUEL PUMP:340
AIR BAG(s):nope
CHIP
CHIP TIMING:26 deg
KNOCK RETARD:none
TEMPERATURE: 98
PEAK BOOST:22
BOOST AT LAUNCH:22
