Historically there have been some different posts about why GN heads don't work, but the common answer is the a/c. As we know, TR headers don't fit TTA heads, so... Here's a prior quote (not from me BTW):
"You cannot use the GN headers with out cutting out the ac box.
The down pipe goes right where the accumulator and box is. "
Supposedly you can put a non-A/C 1LE airbox in place of the TTA unit and get fresh air.
When I was on the gn forums, the common perception was the
F-Body shock towers prevented the heads from being used, but this is obviously not true because several people have stage motors with GN-type heads in TTA's and they did not modify the towers. However, every TTA that I have seen with GN heads had the a/c completely removed.
I'm not going to debate TTA head flow vs TR head flow because you can get both of them to flow well. Stock for stock the perception is TTA heads outflow TR's, but I personally never read any flow results or some common baseline measurement.
Don't mean to misquote or mislead anyone with inaccurate info...
