boosted231
- Sep 13, 2003
I am installing a Terry Houston DP on a TTA. After removing the stock downpipe and trying to feed the new downpipe from the bottom the pipe is so large it is hitting the header flange for the crossover pipe and the frame. I noticed that the factory downpipe has been reduced to fit and I know this th pipe was on a running tta. How do you guy's make this thing fit? The Houston pipe that was taken off another tta has not been bent in any way to fit. Do I have to undo the motor mount and jack the motor up to get this thing in? Do I have to jack the back of the car up to make more room? Once in is this dp going to hit the frame? I know some of you guys have been through this and any pointers you could give me would be appreciated. Such misery for the sake of power. Thanks for your help, Kevin
