TR Custom Parts
Mark Hueffman - Owner
- May 25, 2001
Have a run of TTA header gaskets being made, will be here on 9-28-10. Will have 9 sets available.
SignUp Now!Hi guys,
Fel-Pro has had these for quite some time. They are carried by Advance Auto for $6 or 7 a set. Part #93046. They are steel filled composit.
These are NOT generic over the counter gaskets, they are made by Remflex. Nothing like raining on a guys parade.![]()
Don't buy these. They are worthless...or were for me. Lasted 6 passes.
Jason
Hi Jason!
Really! Would you tell me what you found wrong with the gasket when you removed it? You did check to see what caused the failure, right? I ask this because I had a very expensive set of graphites on my car which I got from the GSCA. I developed a very bad leak after a period of time. When the header was off I found that #1 & #3 had blown out. After checking further I found the problem to be the header flange. I think I have that problem fixed but I do have the Fel-Pro in there. I would really like to know what you found so I will know what to expect. The header is back on and ready to go so I will drive the car untill the problem comes back but, it would be good to be armed with some input and data.
Thanks!
