Hi all, I'm new to the forum. I have a 1980 triumph tr7 with an 85 gn motor with an 86/87 intake manifold, headers etc. with a fmic. I'm contemplating using 7515 tta style fwd heads as I had to dent the crossover pipe slightly to fit into my chassis and they contact the steering shaft making another slight dent necessary. I have ebay crap headers now and would like to replace them anyway they don't fit all that well and leak on the band clamp used on the crossover. oil leaks from the exhaust valves i believe and smokes alot! I would like to use tta style heads because they have the exhaust valve seals they are narrower and would give me the clearance i need and i really want the different ratio rockers and would like to use higher pressure valve spring and use the fwd roller cam. I know about the 9:1 compression but i still have the 85 computer i assume the hot air tune is less radical and i have a fmic so i think ill be ok. has anyone compared the tta headers and the gn headers in person? is just the crossover unique? the flange looks the same and looking at the headers they look identical although the angle could very slightly?
