TTA heads on a GN?
MoscaP87
Mosca85GN
I have a set of ported cylinder heads from an 89 Turbo Trans Am that I want to use on my 87GN. Are they interchangeable without major modifications? I know that the mounting for the valve covers are different, if there is anything else please let me know. Thankyou!!
i have a gn and a tta blocks are the same, you will need to use tta head bolts and get a set of tta headers these are different!!!!!!!!
JD
The flanges are different comparing both headers. If you were to fab up a different header flange and tig them to the GN primaries it may work. I'm not sure about the distance between the exhaust ports though, it may be different....
