Scott89TTA
 - Jul 12, 2005
...should there be an adjustable waste gate on this turbo? Or is the non-adjustable one on there fine? I did install, the .40" orifice, from Johns Performance, into the gray "Y" vac/boost hose, is that ok on this turbo?
whoever installed the turbo probably installed the stock non-adjustable waste gate actuator on the new turbo...with stock DP and intake I'm guessing your boost will probably max out around 17#...stock boost on the TTA was 16.5#. If you have a aftermarket intake (3" tube and conical K&N style) your boost will shoot up to a dangerous 20+ unless you are running Alky injection. Yes, you should get a adjustable waste gate...depending on how much boost you want to run...you will need a standard for 18-20# or a HD that will get you in the 20 and up boost numbers. Make sure you have a Scanmaster so you can monitor what is going on. If you haven't done so you should post your specs so that people helping out know what you have before giving advise
-Scott
